Re: Teflon Tape
Posted by Pete in Holland, MI on May 24, 2013 at 09:04:38 from (198.36.94.34):
In Reply to: Teflon Tape posted by farmerhr on May 23, 2013 at 20:35:05:
I don't use tape as a rule. It is a lubricant,and if there is a load on the pipe trying to unscrew the pipe, it is far easier to unscrew, than when using a teflon-based dope.
If you have to use the tape, 2 wraps is enough, keeping the first couple threads clean, and make sure to wrap in the direction so the tape will get tighter, not loosen & bunch up.
Pete
