Re: farmall 100 mabe
Posted by RTR on May 24, 2013 at 11:19:29 from (216.226.179.180):
In Reply to: farmall 100 mabe posted by John W Martin on May 21, 2013 at 09:38:12:
the casting codes and serial number will date the tractor the best. Just gather all (as many as you can find) casting codes (numbers with a letter) and we can determine the year those parts were cast, determine what has possibly been replaced, and distinguish between the Farmall 100 and 130 since the 130 would have probably used that serial number too.
FYI....the numbers with an "R1, R2, R92, etc" are not casting codes; those are the part numbers.
Post back with what you find!
