Re: Need help Please! H won't start/stay running.
Posted by bill from mass on May 24, 2013 at 14:19:03 from (74.106.76.134):
In Reply to: Re: Need help Please! H won't start/stay running. posted by kevinj54 on May 23, 2013 at 05:53:34:
hook up your 6v battery positive to ground negative to negative.take a digital volt meter and hook it up to the battery red to gound and black to negative turn the key to start the tractor if the meter drop below six volts the battery is no good.I took back two battery befor i found a good one,charge the battery only with a 6v charger on ten amps trickle charged good luck
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
