Re: WD9 has a knock.
Posted by notjustair on May 25, 2013 at 06:43:26 from (174.238.65.60):
In Reply to: WD9 has a knock. posted by Grabatire on May 24, 2013 at 19:52:41:
Rod bearings will do just that. They will also pound like Thor's hammer when you throttle it up quick or load up the engine. The crank will have to be turned or maybe replaced. Tell him to stop running it - he sure doesn't need a window in the side of the thing.
