Re: 350 Utility Rear Hub Play
Posted by mkirsch on May 25, 2013 at 10:23:56 from (64.80.110.75):
In Reply to: 350 Utility Rear Hub Play posted by JeffL on May 25, 2013 at 10:18:27:
In/out play, or round-n-round play?
If in/out, then the bolt is bottoming out before it's tight. Yes, it's tight in the threads but not tight against the hubs.
If the hub is rotating slightly on the splines, then the splines are worn. Had the same problem on a W400. Made up a wrap for the splines out of roof flashing, nice tight fit on the splines. Wheels are nice and tight now.
Better check the other one. It's probably the same.
