Re: 350 Utility Rear Hub Play
Posted by gene bradley on May 25, 2013 at 14:51:43 from (173.216.230.112):
In Reply to: 350 Utility Rear Hub Play posted by JeffL on May 25, 2013 at 10:18:27:
jeffl some of these utility & industrial tractors had this setup there should be a snap ring on the axle behind the hub if it is just out of the groove flip it over it could be broken or gone it must be in the groove pull the wheel before you pull the hub in friendship gene bradley
