Re: 350U Fan Shroud
Posted by CNKS on May 25, 2013 at 18:35:09 from (216.144.104.128):
In Reply to: Re: 350U Fan Shroud posted by Formerly PaMike on May 25, 2013 at 18:17:53:
Bolts are in the four corners of the radiator front to back. Fan pulley is in two parts, one rotates and tightens or loosens the belt. Should have a set screw in it. May be rusted in place. Loosen the screw and tap the front half gently counter clockwise to loosen, clockwise to tighten as viewed from the front. It will break fairly easy. Generator is similar.
