Re: IH 2504 What are all these levers?
Posted by charles todd on May 25, 2013 at 23:50:44 from (70.195.197.199):
In Reply to: IH 2504 What are all these levers? posted by ja1724 on May 23, 2013 at 17:03:43:
In the first pic, the inside lever should be the draft and the outside one the position control (lift). Also in the 1st pic the red arrow pointing to the stub of a lever is a single rear remote valve. The port are on the bottom of the valve, I assume they are plugged. Looks like your quadrant shafts seals are leaking too by the wet axle. Join the crowd, my 504 is bad too. PITA to fix.
2nd pic, IPTO. You can engage and disengage w/o clutching. Nice to have.
3rd pic. Obviously the center lever is the xmission. The LH lever is the TA. Forward is direct drive and back is TA. Shift it fast either way and DO NOT SLIP IT!!! Shift it like you stole it.
Enjoy,
CT
