Re: IH 2500B Bosch VA4 pump and injector issue's, need help
Posted by Dieseltech on May 26, 2013 at 05:08:59 from (199.16.223.2):
In Reply to: IH 2500B Bosch VA4 pump and injector issue's, need help posted by az2tx on May 25, 2013 at 08:31:39:
Sounds like the pump needs a complete reseal. There are some very critical head assembly parts to be careful with as most are no longer available. Had a leaker I could have repaired last month, but owner had been inside and broken the spill plunger control valve, he had to find another pump as parts were not anywhere. He just found another pump. Diesel slobber is normal for some cold running diesels at light or no load. DO NOT adjust the lower lever forward stop screw as it controls rated HP at full load only. Make sure water temp is up too with a good thermostat.
