Re: Need more hyd pressure on 1486. Can I get 3000 lbs?
Posted by T in NE on May 26, 2013 at 09:29:32 from (75.234.243.149):
In Reply to: Re: Need more hyd pressure on 1486. Can I get 3000 lbs? posted by TractormanNC on May 22, 2013 at 16:54:55:
If it folds it has valves in it that keep all the cylinders in time as well. Had one go bad last year in a 16 row 1770 JD. Planter main frame and wings did all kinds of crazy things.
