Re: Farmall H Starting Quandary
Posted by farmallhal on May 26, 2013 at 17:29:39 from (76.0.46.119):
In Reply to: Farmall H Starting Quandary posted by Kevin Little on May 26, 2013 at 16:26:07:
Kevin, If you have a battery cable issue your best positive ground for the 6 volt system will be to the closest 1/2" starter to frame bolt. Use 00 size cable with soldered terminals with the end attaching to the starter bolt sized to the bolt. I also find using an external tooth lock washer (the kind that bites into the metal) between the bolt head and battery ground cable terminal for better contact. With everything being clean and bright throughout the battery to starter circuit that is about as good as it can get. A fully charged 6 volt battery should be 6.3 volts or greater from my experience. Hope this helps and keep us advised as to your progress, Hal.
