Re: Re: BOB M got a question
Posted by Randy on November 20, 2000 at 09:50:39 from (208.163.4.134):
In Reply to: Re: BOB M got a question posted by Bob M on November 19, 2000 at 18:58:33:
Bob to start thanks a ton for all your help!
1.) With the motor off and the key in the "on" position it shows a 3 amp dis-charge
2.)With the motor running at 3/4 to 7/8 throttle with the lights "off" it shows a 3 amp charge.
3.)With the "bright lights" on with the motor running at 3/4 to 7/8 throttle it shows a 4-5 amp dis-charge.
4.)With the "dim lights" on with the motor running at 3/4 to 7/8 throttle it shows a 3 amp dis-charge.
5.)With the lights on "bright" and wire going from the "F" terminal on the regulator to a ground on the tractor it shows a 3 amp charge.
6.) Sounds like the voltage reg. is shot according to what you advised in the prior post. Last I read in a prior post you mentioned that you can adjust the voltage regulator, is that possible in this case or should I just move on and buy a new voltage regulator? Once again your help is very much appreciated!
Post A Followup
: Re: Re: Re: BOB M got a question
