Re: Farmall H Starting Quandary
Posted by SadFarmall on May 27, 2013 at 04:16:50 from (121.79.25.194):
In Reply to: Farmall H Starting Quandary posted by Kevin Little on May 26, 2013 at 16:26:07:
I had a similar problem with my H after I fitted everything new to it. I used it for a couple of days and the nut holding the negative lead to the starter came just loose enough that nothing happened. It all LOOKED fine, but when I moved the wire around I saw the connection slip under the nut. One tweak with a spanner and all was well again. Sometimes the problem is not complicated, but tricky to spot. Do all the easy things first and then move onto the harder ones.
SadFarmall
