Re: Will an H mag/distrib bracket fit an M?
Posted by D Slater on May 27, 2013 at 04:48:51 from (184.14.202.63):
In Reply to: Will an H mag/distrib bracket fit an M? posted by Patrick HMD on May 26, 2013 at 19:38:20:
3 housings were made for a H. Serial 501-268223 without oil seal. 268224-344863 with oil seal and a different drive shaft for the seal. Those 2 used the same bolt pattern to front engine cover.
Housing for 344864 and higher with oil seal and same shaft as the previous housing but a different bolt pattern to the front engine cover.
Also a replacement housing with a different part # from the original was made for 501 to 268223.
Also there"s a gasket between the rear of the housing and the ignition unit.
