Re: BN Wont Fire
Posted by ken house on May 27, 2013 at 13:58:24 from (173.242.241.157):
In Reply to: BN Wont Fire posted by jeffred on May 27, 2013 at 12:32:00:
you say wont fire, i suspect you mean will not run. cut gas completely off at tank, you are having a flooding problem. let it sit for 30 min or so, come back open gas valve and about 10 secs. close it. try to crank and see if it will hit.
solder a wire to a spark plug, not on tractor, to the base and put an alligator clip on the opposite end of wire. remove wire from sparkplug on tractor and put on the spark plug with wire attached, clip alligator to metal on tractor. crank tractor and check to see if plug is firing.
if not firing you have a wiring problem.
