Posted by jimb2 on May 27, 2013 at 15:28:16 from (99.241.76.141):
In Reply to: Re: IHC B-275 posted by JGC on May 27, 2013 at 14:56:05:
Hi, I have an Operators manual for a B-414, the only major difference was B-275 had a BD-144 engine and B-414 had a BD-154 and B-414 had larger rear tires.
To lift the hood, remove the air cleaner top, then there should be a lever on the bottom of each side of the hood by the fuel tank, flip the levers and the hood should tip forward. On top of the valve cover is a crankcase breather cap, this cap is removed by a twist to unlock and this is where the new oil is poured into the crankcase. The crankcase is drained by the plug on the bottom. Becareful changing the oil filter as there are about 3 different O-rings that comes with the oil filter and you have to select the correct replacement and you have to lie on your back and pick all the pieces of the old O-ring out of the filter holder groove and DO NOT over tighten or you will warp the filter housing. If the oil filter canister leaks afterwards there is still a small piece of old O-ring in the groove. We used to only change the oil filter O-ring about every other oil change. Oil and filter change should take about 6.5 US quarts.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
