Charles - thanks for the info. I checked and the remote valve ports are plugged on the bottom. My quadrant valve seals are leaking. Yeah, what isn't leaking on this beast right now!
Do I need to use the clutch to shift the TA?
My PTO shaft is continuously turning. I cannot get it to stop. If I try to push the PTO lever to the rear it just won't go. I didn't know if I should try to 'gorilla' force it?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
