Re: standard narrow front vs. tricycle
Posted by Janicholson on May 27, 2013 at 17:13:41 from (74.60.94.18):
In Reply to: standard narrow front vs. tricycle posted by farmalllh on May 27, 2013 at 16:00:24:
There are several wheel configurations on a single front wheel tractor. The smallest wheel size is often cast iron and heavy. The fork is also pretty stout. The steel wheel singles are some what lighter, but not much. If you are pulling, a single front fork, a custom axle and hub, with a light mag wheel and a motorcycle tire will be about as light as one can get. The hub configuration and bearing situation is unique and not very impressive. Best of luck. Jim
