Posted by Janicholson on May 27, 2013 at 17:24:29 from (74.60.94.18):
In Reply to: '51 SuperC posted by INBrett on May 27, 2013 at 16:54:38:
The probable cause is a bent/warped oil pump cover/end plate. They can and do distort and leak oil that reduces effective pressure. There are no cam bearings in the engine, so it cannot be that. The pump cover can warp or be worn. flat sanding with 200 grit silicon carbide paper on a piece of flat glass can take out marks and flatten the cover. Very thin (available at a dealership) gaskets are used to set gear clearance. (about .0005" to .001") If the pump is good and the pressure stays low, the mains and rods may need to be checked for clearance. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
