Re: IH 31oader
Posted by GeneMO on May 27, 2013 at 19:03:12 from (71.1.102.32):
In Reply to: IH 31oader posted by Bill Bowen on May 27, 2013 at 14:26:22:
Be real careful with it. They work good, but dont lift anything too high, especially when turning. dont lift too high and get the tractor on a slope. It puts a lot of weight on the front end. Without power steering, you can drop in a rut and have the wheel fly out of your hand and give you a nasty sprain or break. Our M had power steering which helped.
Go low, slow, and straight if at all possible.
Try not to raise or lower a load while moving. Raise the load, then move slowly.
Just plain be careful, Gene
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
