Re: IH 350 Utility Hyds.
Posted by T Schwenk on May 27, 2013 at 20:03:01 from (70.198.128.156):
In Reply to: Re: IH 350 Utility Hyds. posted by Janicholson on May 27, 2013 at 17:39:11:
Cub is correct and so is Janicholson. I would make 100% sure that the valves are not wore out and allowing fluid past and I would ask if the cyl is actually moving? I would assume that you have power steering and if so it is priority over the hydraulic valves. If the steering is leaking in the box it will for sure keep a load on the engine.
