Re: '51 SuperC
Posted by mkirsch on May 28, 2013 at 06:59:22 from (64.80.110.74):
In Reply to: '51 SuperC posted by INBrett on May 27, 2013 at 16:54:38:
You've probably never really worked the tractor before, right?
Oil pressure always drops some when you get it good and warmed up.
20-25PSI isn't good to start with on a C. Should be much higher than that.
If truing up the oil pump doesn't help, the engine probably needs an overhaul. Loose bearings cause oil pressure loss.
