Re: Farmall H Rear Axle Seal
Posted by sflem849 on May 28, 2013 at 10:57:28 from (69.197.84.39):
In Reply to: Farmall H Rear Axle Seal posted by Zachary Hoyt on May 28, 2013 at 10:49:30:
I actually greased the snot out of my axle, but wish I would have used tin or paper. I heard about that trick about one week too late. :lol:
There really aren't any suprises in there. Don't pull the bull pinion carrier without removing the bull pinion gears. Other than that it is simple. You won't need to pull them, but I thought I would bring it up incase you start replacing a lot of stuff in there. Also, check the axles for play. If a bearing is going out it will cause an axle seal to leak.
http://s1246.photobucket.com/user/sflem849/library/#/user/sflem849/library/Farmall%20H?sort=3&page=1&_suid=136976383714307130567697060791
