Re: D358 to D310 injector pump swap
Posted by Dieseltech on May 28, 2013 at 12:31:16 from (98.206.80.148):
In Reply to: D358 to D310 injector pump swap posted by Brian686 on May 28, 2013 at 10:42:07:
Need more info, the Bosch ten digit # of both pumps would be helpful. Example 0 460 306 xxx. The advance range of the specs I found was 5 to 8 degrees. Has the pump you have on now been used recently, or been setting unused? It may have transfer pump blades stuck causing no advance at all. It may need a clean and reseal to work again.
