Re: D358 to D310 injector pump swap
Posted by Dieseltech on May 28, 2013 at 12:41:59 from (98.206.80.148):
In Reply to: Re: D358 to D310 injector pump swap posted by Brian686 on May 28, 2013 at 12:34:03:
Also make sure you have the return valve bolt at top in return line. Will fit in inlet and cause your trouble too. CR pumps don't use this valve bolt but AR and BR pumps do. Have seen the bolts get switched before as both are the same size.
