Re: W4 Belt Drum/PTO
Posted by mmm59 on May 28, 2013 at 13:20:43 from (69.158.88.41):
In Reply to: Re: W4 Belt Drum/PTO posted by sflem849 on May 28, 2013 at 06:58:02:
Problem solved. Must remember to look at the simple
things first. It turned out to be a loose bolt on
the PTO engagement linkage that would not allow PTO
shaft to engage properly.
Thanks for all the help.
