Re: f 20 oil pan gasket, is there such a thing anymore?
Posted by 36F30 on May 28, 2013 at 16:44:55 from (63.153.214.23):
In Reply to: f 20 oil pan gasket, is there such a thing anymore? posted by SDE on May 28, 2013 at 16:40:44:
SDE said: (quoted from post at 16:40:44 05/28/13) Do I need to use a pan gasket? Do I need to make one from other gaskets or do they still make them?
Thank you
SDE
You can get em from the Fordson House, Aldersons Tractor and probably quite a few other places too.
10417-D $6.30 from https://www.thefordsonhouse.com/storefront.asp?cat=5 Make sure to use sealant on the bolts, they protrude into the block and like to leak.
This post was edited by 36F30 at 16:46:08 05/28/13.
