Re: Farmall 706 Gas Rod Noise?
Posted by Jerry Hewes on May 28, 2013 at 17:03:50 from (12.45.21.95):
In Reply to: Re: Farmall 706 Gas Rod Noise? posted by notjustair on May 28, 2013 at 12:18:59:
I run an M, 300 and 400. My neighbor has a 656. I do all the service work. All of these tractors will "knock" at very low idle speeds. Never had a problem. Nothing evident on overhaul. I suspect slap of the piston skirt against the sleve with particular vibrations or oscillations in RPM due to being an internal combustion engine and/or imprecise ignition timing aka detonation.
