Posted by CharlieNJ on May 28, 2013 at 19:17:43 from (76.117.68.151):
In Reply to: play in left axle posted by JT90 on May 28, 2013 at 18:33:13:
It is not clear to me they way you describe the problem. If you "shake" the wheel from left to right at the top, and the distributor gear moves up and down, then it would be bad bearings. If you shake the wheel fore and aft, and there is some play, then it might be the spline on the axel shaft or the bull gear worn. If you jack up that wheel, look carefully as the weight comes off the wheel, if the wheel moves at all independent of the tractor, the bearings are bad. Once the wheel is off the ground, put the transmission in gear and rock the wheel forward and backward to see where there might be some play at the bull gear. Regards, Charlie
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
