Re: play in left axle
Posted by Janicholson on May 28, 2013 at 19:19:44 from (74.60.94.18):
In Reply to: play in left axle posted by JT90 on May 28, 2013 at 18:33:13:
Making some assumptions here!!
Assuming it is the front steering that is loose.
Assuming that the 1/2" of play is in a tie rod end under the front of the tractor where the center steering arm attaches.
The tie rod end may be worn radically and need replaced. (some may be adjustable, but with that much play, it likely needs to be replaced. OR
it could be the steering arm loose on the steering shaft. There is probably a woodruf key that is worn or augered out and loose. We need to know what is happening a picture would be good. Jim
