Re: Super A crankshaft help
Posted by CharlieNJ on May 28, 2013 at 19:41:51 from (76.117.68.151):
In Reply to: Super A crankshaft help posted by Woodby on May 28, 2013 at 14:52:45:
You should have an engine stand. Then you can turn the engine upside down, although you could do it on a bench. Remove the front pulley. Remove the oil pan. Remove the oil pump. Remove the timing cover, Remove the rear main seal carrier. Check the top of the cylinder liners for a ridge, cut it out if necessary. Remove the piston connecting rods one at a time, notice the numbers that are on the cam side. Keep the piston rods and caps in the same position and bolt them together hand tight. Remove the main bearing caps, taking care to keep them in order and same position. Now, the crankshaft should now lift out. Measure the crankshaft journals at two locations each, 90 degrees apart. If they are in spec, get some Plasti-gauge and measure the bearing clearance between the crank and the old bearings. Any questions?
Regards,
Charlie
