Re: play in left axle
Posted by Janicholson on May 28, 2013 at 20:25:55 from (74.60.94.18):
In Reply to: Re: play in left axle posted by JT90 on May 28, 2013 at 19:38:29:
Now that it is clearly the rear wheel. and also assuming it is axial play (in and out of the axle) not looseness as in wobble. The small cover in alignment with the main axle on the inside can be taken off for access to the inside end of the axle.
The bull gear is the big gear inside the housing driving the axle through the splines.
The diagrams also show the bearings and spacers. If the link does not work, try caseih.com select country, then Parts at the top. Then select the on line parts store big screen (looks like a computer screen) then select find parts by model then select search. Then put in Farmall 140 then select drive train, then final drive.
