Re: Trying to ID what type of distributor
Posted by Janicholson on May 29, 2013 at 08:07:29 from (199.17.6.25):
In Reply to: Trying to ID what type of distributor posted by jkmdg84 on May 29, 2013 at 07:51:34:
Facing rearward it is likely to be IH. If IH it will have a IH logo on it as well as a part number. (not specific to that tractor (which you did not specify)) Cleaning the existing points, unless burnt off to nothing, will assure at least that issue is OK. 340 or 400 grit then wipe with a folded dollar. (no fuzz) point gap is .020" Jim
