Re: Super A crankshaft help
Posted by Rootsy on May 29, 2013 at 12:57:14 from (63.86.92.107):
In Reply to: Super A crankshaft help posted by Woodby on May 28, 2013 at 14:52:45:
Have one apart right now with a broken crankshaft. Since it is split and the flywheel is off you are about 1/4 of the way there. The front pulley is the real PITA to contend with. They can be a bear to remove. Once it is off, remove the front cover and the rest is easy, just unbolt the rods and push the pistons down in the bore. Remove the cross struts on either end that support the pan. Rear main assy unbolts, it is two halves, remove main caps and the crank lifts out. Will have to remove the oil pump also (2 bolts on outside of block and it pulls out).
