Re: Oil in F-30
Posted by robgIN on May 29, 2013 at 18:38:22 from (70.224.39.34):
In Reply to: Oil in F-30 posted by Mark Poss on May 29, 2013 at 02:34:48:
I use 30wt, but I think 15-40 would do just fine also, I think it holds 7qts if my mind is currently functioning correctly.
