Re: 6 or 12 volt question
Posted by Nebraska Cowman on May 30, 2013 at 08:05:22 from (166.182.3.118):
In Reply to: 6 or 12 volt question posted by charlie M on May 30, 2013 at 07:43:21:
You can probably look up the tag number on the generator and determine if that item is 6 or 12 V. Presence of a ballast resister ahead of the coil would likely indicate 12 V But absence of it not necessarily. Most coils or voltage regulators are not marked once you take them out of the box. If you hook a 12 volt battery to it and the lights come on real bright and then go out you can bet they were 6 V bulbs. Good luck
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
