Re: adapters to convert 2pt to 3pt
Posted by The tractor vet on May 30, 2013 at 08:29:41 from (75.19.121.30):
In Reply to: adapters to convert 2pt to 3pt posted by VA Gasman on May 29, 2013 at 19:22:10:
I use to build a set that were adjustable for CAT 1 and 2 three point and were tough enough to handle a five bottom semi mount plow . but it has been 12 years since i made the last set. . I had a jig made up to build them in and i had a steel supply house that would order in the stock for the prongs as it is not a common stock bar . The one local weld shop had a CNC burning set up and the program to cut the notch and they would burn out a dozen at a time from my bar stock. the rest was 1/2 inch x 4 bar stock and scd 80 pipe with weld on Cat 1 and 2 ball sockets. I would then sell a couple sets a different consignment auctions . back then they would bring 225 to 275 a set. I am still usen one set for my 806.
