Re: Changing condenser on F4 Magneto
Posted by red.green on May 30, 2013 at 09:39:25 from (76.209.50.57):
In Reply to: Changing condenser on F4 Magneto posted by Fawteen on May 30, 2013 at 09:06:54:
On theF4 you have to disassemble it quite far to change out the condenser. After removing the distributor cap you have to remove the magnet band and the magnet. After that the dust cover under the magnet, there are four screws holding it down, two at the back of the cover going down and two more at the front going up. Once the cover is removed you can see the condenser. Loosen the nut and disconnect the wires, then remove condenser, reclamp new condenser and reassemble.
