Posted by harpo on May 31, 2013 at 04:49:47 from (199.193.96.237):
In Reply to: H transmission seal posted by Oldbolter on May 30, 2013 at 19:06:37:
You do not need to loosen or remove the pressure plate. You can take the whole assembly out if you juggle it right. That will let you check the pilot bearing on the top shaft and the bearings in the assembly. If the seal is leaking chances are that one or both of the bearings are getting sloppy.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
