Re: H transmission seal
Posted by Oldbolter on May 31, 2013 at 20:23:18 from (76.164.161.77):
In Reply to: Re: H transmission seal posted by Janicholson on May 30, 2013 at 20:01:53:
I must be missing something. The liftall is out, the coupling between the engine/transmission is disconnected, the bolt holding the yoke to the shaft is removed.
Now, it appears I simply need to remove the yoke so the seal can be installed around the shaft. How do I remove the yoke from the shaft? Or, am I going about this all wrong?
Thanks again for your help in what is probably a straight forward process to the experts who done this previously, but seems problematic to a first timer.
