Posted by The tractor vet on June 01, 2013 at 07:31:35 from (75.19.115.103):
In Reply to: 706 gov posted by farm-al on June 01, 2013 at 05:31:06:
I think your problem is that you do not have the carb scyed to the gov.Remove the headed pin that holds the linkage from the gov to the carb. Then pull the hand throttle wide open and move the carb throttle shaft to wide open and see if the pin will slide in . If nothing lines up then you must adjust the clevis on the rod so that the pin will slide in freely then add one half turn out and install the pin and replace the cotter pin and try it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
