Sounds like a chipped tooth on the constant mess gear and it will not heal it's self . More then likely this was caused by the transmission input bearing getting bumped at some point during a T/A replacement and one roller fell out and got under the gear . When one splits a I H tractor it is vary wise to place a heavy rubber band around the transmission input bearing to hold all the rollers tight when going back together and also be in perfect alignment and NO slamming jerking , pulling together with bolts . If they do not SLIDE together then your not aligned . If it is ONLY the constant mesh gear then your lucky as i have seen the bottom of the transmission busted out from a bearing roller getting under them .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
