Posted by Oldbolter on June 01, 2013 at 18:11:30 from (96.125.231.19):
In Reply to: H transmission seal posted by Oldbolter on May 30, 2013 at 19:06:37:
Thanks for everyone's help. We finally removed the yoke from the transmission without removing the pressure plate, etc. Here's how we did it: loosen the yoke retaining bolt enough to hang a 3/4' closed-end ratcheting wrench on the bolt head, then bolt a 1/4" thick steel strap (drilled to match the yoke bolt holes) across the face of the yoke, then back the yoke retaining bolt out using the 3/4" ratcheting wrench that was attached earlier. As the retaining bolt head pushes against the steel strap it pulls the yoke off the shaft. Everything is a tight fit, but there is just enough room to get the yoke off the shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
