Re: 460 flywheel bolts
Posted by pete 23 on June 01, 2013 at 19:36:58 from (74.44.101.209):
In Reply to: 460 flywheel bolts posted by bob7337 on June 01, 2013 at 07:43:58:
Original equipment was a grade 8 place bolt (six slotted head) and torqued to 60 ft lbs. This type of bolt locks by deforming the head when torqued. Also, use sealer on threads as the holes in crankshaft go right through. Can't tell you the length though so probably not much help. Just long enough to full thread in crankshaft though.
