Re: PTO problem
Posted by gene bender on June 02, 2013 at 02:26:12 from (67.55.226.83):
In Reply to: PTO problem posted by manning on June 01, 2013 at 21:09:20:
When the key messed up the gear is now froze to the shaft you will need a press to remove the gear off the shaft. Its possible the shaft is now scored enough when the gear is put back it will not be a good fit and you mite need to replace the whole assy. Parts can be found at a salvage yard. I have one for sale if you need it. Yours should be the 1 3/8 spline. Make sure the shaft didn't bend when the key sheared.
