Re: Engine won't STOP running
Posted by equeen on June 02, 2013 at 05:55:20 from (209.102.248.236):
In Reply to: Re: Engine won't STOP running posted by John T on June 02, 2013 at 05:14:30:
Ah, so.........
Hmmmm? So, power from the battery to ammeter to post (a or whatever) on ignition switch goes to post (b or whatever) on ignition switch when it is pulled on, then down wire to coil and other wire to generator to exicte her on spade terminal 1.
The #10 wire from the alternator provides the charge through the system to the battery.
The #1 spade terminal gets its hots from the battery (at least initially) to excite that unexcited alternator and get her to charge.
And, since the wire from #1 spade is connected to the same post on the ignition switch as is the wire to the coil - the alternator keeps current flowing to the coil as long as the alternator is spinning.
So, by magic, a resistor allows current to flow only one way???? It allows the needed current/ excitement to get the generator to charge, but prevents her from backfeeding to the coil.
Do I get it now?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
