Re: Engine won't STOP running
Posted by old on June 02, 2013 at 09:50:10 from (209.86.226.57):
In Reply to: Engine won't STOP running posted by equeen on June 01, 2013 at 19:54:15:
Well this is how the alternator works in simple terms. You have the big stud on it which is the charge output. The #2 wire tells the V.R. when to slow down or shut down the alternator. Then the #1 wire is the excite wire and once excited that wire stays hot with or with out the ignition switch on till the alternator stops spinning so your problem is that the alternator is back feeding the ignition so you have no shut down. Install an Radio shack 276-1661 diode in the #1 wire line towards that alternator and your problem will be fixed
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
