Re: 140HC Steering box rebuild
Posted by muleboss on June 02, 2013 at 12:05:54 from (67.239.112.66):
In Reply to: 140HC Steering box rebuild posted by Rex Simpkins on June 02, 2013 at 11:32:25:
Just repaired one last week. Replaced both bearings( one in steering shaft end and one in housing. Bushings were ok.
Complete repair would be 2 bearings, 2 seals , 2 brass bushings, and 1 gasket if gears are ok. Easy fix.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
