Re: 6 Volt H Generator Jump Start Emergency situation
Posted by Bob M on November 20, 2000 at 16:10:16 from (172.143.58.100):
In Reply to: 6 Volt H Generator Jump Start Emergency situation posted by Bob R on November 20, 2000 at 15:50:04:
A 12 volt jump on a 6 volt tractor works fine - I've had to resort to it many times over the years, and still do on occasion. A few things to watch out for:
1 - Make sure you connect + to + and - to - on the two systems. That means if the 6 volt system is positive ground (which they usually are) and the 12 volt is negative ground (which is almost universal) the red jumper cable must go from the + post of the 12 volt battery to the frame on the 6 volt tractor.
2 - Wear safety glasses, and make the final jumper cable connection to the frame on the tractor being jumped. You're probably gonna get a spark when you do, and you want it as far away from either battery as possible.
3 - Disconnect one of the jumper cables as soon as the tractor being jumped fires. You don't want the 6 volt cutout relay closing while it's still hooked to 12 volts!
4 - So long as you observe proper polarity when connecting, neither system's generator, regulator, etc. will be affected
5 - As long as the 6 volt lights are turned off, they wont't be affected by a 12 volt jump.
Above all, BE CAREFUL!
Post A Followup
: Re: Re: 6 Volt H Generator Jump Start Emergency situation
