Oil? (or smoke?) coming from valve cover breather/fill tube??? Don't know what it is, but it looks nasty. Will try and find out. Maybe hold a white rag around it while running?
Filter and oil (NAPA 30 HD) changed in 2011. Hmmm? Maintenance log shows adding Marvel Mystery Fluid to oil (didn't note how much) back in 2011, then ran engine for 10 mins and no smoke. Hmmmm?
No dipstick on this engine. Those two petcocks to check high/low oil level.
Will be replacing valve cover and oil pan later with ones already cleaned and painted. Will check for crud then.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
